New to solar and home backup power feedback and design recommendations on CKT Breaker and wire sizes for my new project
fbh31966
Feedback and design recommendations on CKT Breaker and wire sizes for my new project
Disclaimers
  • I want to add isolations/breakers where I can to make the system easy to install and isolate for easy installation, expansion and removal.
  • I plan to add about 10-15KW of solar
Current inherited configuration PNG
100 Amp service
Manual Transfer
Position 1-Grid power feeds Main power panel (has no main breaker) that powers the entire home
Position 2- Off House is isolated from the grid
Position 3-Generator
Desired Configuration PNG
Desire is to add a system that can be easily isolated and removed (this is not my forever home)
Grid tied with a battery backup using the following
(2) RUiXU | Lithi2-16 | 51.2V314Ah 16kWh Battery Storage UL1973 ,UL9540A
(2) EG4 6000XP Off-Grid Inverter
Manual Transfer
Position 1-Grid power feeds New Subpanel with 100 Amp main breaker to isolate the entire house from the grid
Add the following Square D - HOM1224L125PC Homeline Load Center 125-Amp
  • 100 Amp breaker to feed the Main Power panel
  • 50 Amp breaker to feed primary EG 4 6000XP
  • 50 AMP breaker to feed 2nd EG 4 6000XP
Add a second Square D - HOM1224L125PC Homeline Load Center 125-Amp
  • 50 amp Main Breaker that will feed inverter power to the a 50 Amp breaker in the main panel
  • 50 Amp breaker from the Inverter 1 Load
  • 50 Amp breaker from the inverter 2 load
PNG's attached
