cws2011
Hello.
Here's what I'm thinking of trying to accomplish. We currently have a generator running two sewage/submersible pumps. The pumps are just standard 3/4hp 110volt pumps with on/off floats to control them. What do you guys recommend for me to be too able to run these two pumps. I want to avoid batteries, just to keep the overall maintenance cost low. Running the pumps only when the sun is out is perfectly fine.
Now some of my concerns/questions.
1st off, When the sun is out, and producing power, without batteries, can the system produce the power and it go unused? I understand it will be wasted.
2nd, Is there a controller/invertor that has the capability of doing 110 and 220 in case we ever up to one 220 volt pump instead of the two 3/4 hp 110 pumps?
3rd. Would I be better off trying to find a variable speed pump now? to keep lower power needs since I won't have any battery backup?
Thanks for any help or guidance.
