I really think you need to find out your expected consumption rates and plan from there. If you want to do something like a already made solar power generator, need to really look at the specs. THey don’t make a lot of power so see if that work for you. One thing that steered me away from that direction is the ones I looked at are limited in the amount of 12 volt panels that can hook into it, either one or two panels.
Most places you can expect 4 solar hours of charging, which in my case in Arizona is my long sunny days because the sun doesn’t deliver full power to my panel because the angles move as the sun moves, so with 200 watts of panels hooked up, I can expect to put 800 watt hours of energy back into it. That is not a lot of energy at all. Some of the units I looked at were 1KWH, so if I plugged it in all day, I could get 800 watt hours overnight. That is, I could watch TV for 2 to 4 hours.
I didn’t want to be limited like that, so I ended up getting a system I’m finishing my phase 1, where I can charge it with 600 watts of roof mounted panels. Phase 2 is adding 400 watts of ground panels, and phase 3 will be 300 more watts of roof mounted panels.
As I’m browsing a site on the Bluetooth AC200, seems my system I’m installing myself will be cheaper than the AC200 plus four of their solar panels, and an AC charging cord. I will have 5200 WH of lead acid batteries, which I can use 2600 WH per day.
