@Hedges is a big array guy, maybe this will conjure him and his insights with SunnyBoy equipment (also high quality and missing from my notes).
I can't hear the "@" sign. Just stumbled onto this thread.
5 in series is too much. Just a few degrees below rated temp (25 deg C) and they produce over 50Voc each. That is the one number to never exceed lest you let the magic smoke out.
Conversely, 5 strings of 9.45amps (~40amps total ) is quite a to deal with too in terms of wire size and fusing.
An SCC that takes higher input volts will likely be easier to match an array to. Might even be cheaper depending on the length of your wire run from array to SCC.
One of the images shows 80A PV input, so 4s5p for 200 Voc, 50A seems reasonable.
Some 4s strings can orient towards sun at different times of the day, reducing peak power and increasing hours of production.
SMA Sunny Boy is one of the top-quality high voltage string GT PV inverters. I've used them about 17 years, with about 35 years MTBF (two failures out of 5 units in that time). One was repaired in warranty during its first 5 years. After decades, more practical to swap in new models, or used or new-old-stock rather than repairing.
You can use some GT PV inverters in an off-grid setup if they play nice with battery inverters (implement frequency-watts).
The high-voltage strings work well for single string into an MPPT (any shading activates bypass diodes.) If multiple strings in parallel, small amount of shading is OK but 33% to 50% shading of one string causes additional power loss, not running other panels optimally.
There are high voltage SCC as well, but they tend to cost more per watt than lower voltage SCC. Maybe due to what it takes to charge a 48V battery from PV that is 5x to 10x as high voltage. So I find AC coupled PV more cost-effective than DC coupled.
So I could run the Schneider 600v along with my growatt 12k and use the growatt as inverter ac power and additional panels(if I get to a place I can have a closer array) and use the Schneider as my large array charge controller ????
Will your battery be so large, and at such a low SoC, that GroWatt can't recharge it in a day? Do you need higher charge rate by adding a separate charge controller?
I think Growatt supports AC coupling.
If you DC couple, does Growatt have a way to know battery state of charge? For my Sunny Island, a battery shunt would be the answer.
How much is the Schneider 600V? Looks to me like $1400 for 6kW
Designed for large DC coupled solar/storage systems, the Conext MPPT 100 600V solar charge controller can output 6kW and offers easier, cheaper installation.
realgoods.com
I can find recent model Sunny Boy GT inverters around that price. Older models I've bought cheaper, around $100 per kW.
If Growatt does frequency-shift to manage GT inverters, then Sunny Boy, Enphase, and others could be used.
Growatt has a maximum AC output in the 8kW or 9kW range. With AC coupling you might be able to have several kW more while the sun shines, good for running A/C and the like.
