For reference, here is the post where a Forum Member was quoted $960 + $260 DDP (shipping and duty) on the 10kW split-phase SRNE inverter: https://diysolarforum.com/threads/a-catalogue-of-all-inverters-in-one-place.65743/#post-826386
Yea but I'm not able to order unless I use a bank transfer... ?For reference, here is the post where a Forum Member was quoted $960 + $260 DDP (shipping and duty) on the 10kW split-phase SRNE inverter: https://diysolarforum.com/threads/a-catalogue-of-all-inverters-in-one-place.65743/#post-826386
Why is it called a hybrid inverter? It looks fully off grid to me
It has an AC input and you can program the times you want it to power critical loads from grid rather than from battery power…Why is it called a hybrid inverter? It looks fully off grid to me
It can export per the manual. I'm trying to get one to verify / be a guinea pig... Figure I'll eliminate middle man in the process...Why is it called a hybrid inverter? It looks fully off grid to me
This is a rebadged version of the same inverter sold through Amazon: https://www.amazon.com/Inverter-Spl...mzn1.fos.17f26c18-b61b-4ce9-8a28-de351f41cffbYea but I'm not able to order unless I use a bank transfer... ?
Sunevo Solar Co Ltd. Anyone?
Has anyone done business with them? I'm ready to make an order, looking for last minute reasons not to. https://sunevo.m.en.alibaba.com/company_profile.html https://sunevo.m.en.alibaba.com/index.htmldiysolarforum.com
Thanks.This is a rebadged version of the same inverter sold through Amazon: https://www.amazon.com/Inverter-Split-Phase-Single-phase-Connection-Activation/dp/B0BMWVNKXK/ref=mp_s_a_1_4?keywords=10kw+inverter&qid=1691550588&sr=8-4&ufe=app_do:amzn1.fos.17f26c18-b61b-4ce9-8a28-de351f41cffb
And you can also get it from Y&H through EBay for under $1600 ‘or best offer.’
It can export per the manual. [/b{
Looking forward to your opinion…I'm trying to get one to verify / be a guinea pig... Figure I'll eliminate middle man in the process...
Megarevo vs SRNE
Debating between Megarevo R10KLNA and SRNE ASF48100U200-H for our inverter. We'd like the option to be hybrid, but will mainly have the system back feed into a interlocked electrical panel. Curious to hear everyones thoughts on the two. The Megarevo is about double the cost of the SRNE...diysolarforum.com
Pretty sure these are rebadges, not clones.Thanks.
I wet there are at least a half dozen SRNE clones out there.
Pretty sure if you offer $1500 on eBay you can score one. Not sure about $1200…I'll check out the ebay option.
I'll gamble with it ~1200 but if I'm spending ~1600 I'd probably jump up to 2 6548s..
Agreed. I tend to interchange clone and rebadge...Pretty sure these are rebadges, not clones.
I'll spend another day messing around on alibaba before the ebay.Pretty sure if you offer $1500 on eBay you can score one. Not sure about $1200…
Interesting. I wonder how it would do that? Sending back power on ac input line?It can export per the manual. I'm trying to get one to verify / be a guinea pig... Figure I'll eliminate middle man in the process...
Megarevo vs SRNE
I don't know exactly, that's above my expertise (for now).Interesting. I wonder how it would do that? Sending back power on ac input line?
Yes, but not control the export. All excess or zero.
They have UL.Not very useful in the US without UL listings. If only they had some CT's and limiting features like their GTIL's.
I’m sure you read the other thread…Trying to order from SRNE direct... Still a few hundred cheaper than any US outlets.
I'll start a new thread here soon...
The one on amazon from Y&L has UL Listing? It's not listed on their ad, or visible in any of the pictures.They have UL.
They do not support export limiting with external CT sensors or power meters.
This other model does support zero export, not splitphaseThey have UL.
SRNE has UL certification and the inverter itself is almost certainly labeled UL.The one on amazon from Y&L has UL Listing? It's not listed on their ad, or visible in any of the pictures.
That is a single-phase model - not really relevant to this thread (oh, just saw you already noted that).This other model does support zero export, not splitphase
I seen zero export mentioned by someone else before I commented. Zero export to Ct is what the inverter in the link I shared has. If merely trying to use the zero export to Ct functionality to cover all of the splitphase main panels 240v and 120v loads, then all that is needed is a single phase zero export grid tie inverter.That is a single-phase model - not really relevant to this thread (oh, just saw you already noted that).
And also, zero-export is probably less descriptive than ‘zero-export to CT’ or ‘export to CT’…
