Hello! Killer forum here!
I purchased 4 280AH prismatic cells from AliExpress for my Old Town Autopilot electric Kayak. I was using a 100AH Relion that was ok but would not last the whole day running upstream pretty wide open. I also purchased the Daly 120 Amp, 4s, BT smart BMS. It’s wired up correctly and I’ve checked this thing 25 times to verify. Total battery voltage is 13.33 volts when I put the multimeter on main +/-. I checked the cells and the individual voltage is as follows.
1.) 3.32
2.) 3.32
3.) 3.32
4.) 3.29
When I touch the multimeter to battery + and P-, I get 10.43 volts. When I touch the multimeter to battery + and B- on the BMS, I get 13.33 volts. I’ve hooked it up to my 5 amp, 3 bank Minn Kota charger and I don’t know if the BMS is working. When the charger is hooked up to battery + and P-, I get 7.33 volts.
The BMS came with Bluetooth and a usb cable but it does nothing when I connect the BMS to my laptop and there is no BT device in my Bluetooth list. I am using an iPhone with iOS and a PC for the USB connection.
I have no clue if I’m about to blow anything up.
1.) Should I let’er eat for a few hours on the charger or am I doing something wrong?
2.) Shouldn’t I get the full battery voltage when the multimeter is connected to Battery + and P-?
3.) How can I tell when this BMS kicks on?
I’ve tried the shorting out of the BMS with the P- to B- and I still get 10.43 volts at P-.
I’m only a halfway idiot with electronics so be patient with me.
Thanks in advance!
1.) 3.32
2.) 3.32
3.) 3.32
4.) 3.29
Thanks in advance!
