BretS
- Mar 30, 2021
- 171
Getting started on solar for my 5th wheel to enable boondocking at times. I am doing this in two phases, with the battery bank, inverter/charger/DC-DC charger first, and then after that is all working good (and I save a bit more money), the panels and solar charger second. Wanted to run my basic plans by you all for input. Thanks in advance!!
- My 5th wheel currently has a factory 1200W inverter tied to only the residential fridge.
- I have a soft start to install on my 15K A/C.
- I have a 3400W dual fuel inverter generator.
- I have ordered twelve 3.2V 310aH cells to make a 930aH, 12V battery bank.
- Here is my basic idea for the system (except the bank above in place of the BBs, and Victron's new inverter in place of the Magnum)
- Here are the Victron components I am looking at so far:
- I need to figure out what to do for a BMS for that battery bank next. Also need to know what I need in order to balance and build the batteries... learning about all of that.
- Another question I had: Would it be a good idea to leave the 1200W inverter and residential fridge circuit in place and separate, and just connect the inverter to the new battery bank? I was thinking that would leave capacity on the new 3000W inverter for the A/C and other loads - and the wiring to the receptacle for the fridge is already separate. Let me know your thoughts on this.
Thanks again for any help!
