Hi all,
I've been working on a 24v system for my conversion and I've been trying to follow will's 24v guide here (https://www.mobile-solarpower.com/2000-watt-24v-solar-system.html) I'm having an issue with my system where I was able to get my inverter running but when connecting a 12v fan to my fuse block, the fuses keep blowing. I have a 24-12v buck converter placed in the same spot as the guide.
The picture I'm attaching is after I asked advice from a facebook group and was told its better to use a busbar instead of using an anl fuse as a busbar for the inverter/CC shown in wills guide.
I was also advised to use more fuses, which I intend to and correct me if im wrong but the system should still function for a test without some extra fuses here and there right?
Also, should I be using a battery protect similar to the guide shows? I'm using the same inverter and all.
Thanks in advance!!!
