Hello bright minds,
I have serveral 48V rack mount style pack. It has two positive and two negative terminals on it. I have the appropriately sized cables with a fuse and breaker going to the inverter depending on the inverter size (some will only accept 8AWG or 6AWG).
My question is I am about to tie both of my arrays together which will allow for input amperage way higher than the breaker/fuse setups for some of these light duty inverters. If I hook up my solar power from my SCC using something like say an Anderson connector connected to one set of the + and - terminals and lets say its charging the battery at 60Amps, will that cause the other set of terminals connected to inverter (light duty ones) to have the breaker trip and the fuse pop since they are not rated to handle that kind of load, or will the 60A simply flow into the battery and charge it and the "output" (to the inverter) will be independant and draw only the amperage it need based on the inverter load? Say 10A (max) for a small 250watt inverter I have.
The charging of the battery shouldn't impact the power being drawn from the load right? Meaning the system isn't going to bypass the battery and take its power from the incoming 60A and bust up the breaker/fuse/inverter?
I'm drawing a total blank on this I dont think its an issue but I'm looking for confirmation. I'm pretty sure I've had my array charging a pack that had a light duty inverter powered on and providing power to devices and it didn't trip or bust the fuse. I think....I think....
This is how I over complicate myself sometimes. This should be a non issue right?
