Nope. EU is waaaay behind US in off-grid system installs.
We have a LOT of grid-tie ... but off-grid way less (hybridized grid-tie's without backup box count as grid-tie, sincs in a blackout they stop working even they have a battery installed).
In the last 2 year it changed but still there is a 10 year gap.
The main reason is legislation and utility companies.
Off-grid with grid support inverters (that can do Peak shaving with internal backfeed protection) are still in the grey area.
These are the MPP Solar/Voltronic Axpert (and clones like EASun, Must, PowMr) inverters.
In many countries even if you use it like an UPS (no Peak Shaving, power comes from utility OR inverter) it is not considered as an Off-grid inverter (and needs permit or registration or ... ).
The other reason as you said: no blackouts in EU.
Because we have a much more stable grid so we do not prepare for blackouts.
And the next big EU blackout is on the corner ...
Many EU countries prepare the people for a big winter blackout
And they have a lot of reason to do so.
In 2021.01.08 the whole EU grid merely get away.
The EU power grid separated into two part.
The north part exported a lot from the south ... and one tiny not so significant station disconnected with overload.
The frequency dropped in north and rise in the south.
The automatic systems could stop it before it became a cascade.
But now the winter power consumption will be much higher because of the extreme high propane prizes.
