mrzed001
Voice of reason
My point was if you scan around through solar in Europe if anything it’s more diverse then anything in the US. There’s are net metering grid tied , non grid in abundance. Many countries have very different setups often driven by public policy initiatives and tax rebates.
But it’s as if not more diverse then the US that’s for sure.
Nope. You did not read my post thoroughly.
EU is basically Grid-Tie only. Different types of grid-tie ... but only grid-tie.
Of course since the grid is so good why would anyone in their right mind not want to have a connection everyone dors there’s none of this “ anti grid anti Gov anti authority politics “ which are behind some of the US non grid installs. It’s all political nonsense.
Again, read my post. Off-grid with grid support systems HAVE GRID !
By the way grid tied in a blackout DONT stop working you just have to have the correct anti-islanding system installed. My friend has just that. Please educate yourself as to the various country codes. He’s on a heavy forested area and suffers from tree fall.
The future is thd grid, all hail the grid. Get in line comrades
And this is nonsense.
If you have a simple Grid-tie like Fronius Symo/Primo, SolarEdge, Huawei, Enphase, ... system IT WILL STOP WORKING IN A BLACKOUT !!!
You can not do anything against it (except AC coupling it with a real Hybrid)
If you have a hybridized Grid-tie like Fronius GEN24 or Huawei M1 then you can install a Backup Box IF your utility company allows it.
And from them only GEN24 is able to produce 3 phase asymmetric power ... Huawei gives only 1 phase 3300VA.
Of course there are the real Hybrid inverters like DEYE, SAJ, Sungrow ... and they will give power even in a blackout but only in the PROTECTED LOAD side (they disconnect the GRID side).
You have much to learn in the hybrid part.
