gray webber
- Feb 4, 2022
- 202
Hello!
Already posted some on this forum. Have learned a great deal from members.
I’ll take a moment to explain my solar goals in case some here will pitch in some knowledge I can benifit from?
My project:
Off grid camp on 24 A and creek-love the land.
1600 watt load per day
Limited winter use but winter here is 6-7 mo.
1760w -4panels Bi-facials
Midnight solar combiner box. 2s and 2p
Midnight Solar classic 150 charge controller
Victron Multiplus 24-3000-70 inverter charger
2-12volt 300ah lithium iron ion batteries
Insulated heated battery box in solar box -90ft from camp
Main issues yet to figure:
1. Love the info Victron BMV 500 provides but blue tooth service of 100ft is a big issue
Working to find answer that will work. Could use Renogy BMV but need to run another cable?
2. In case heated box fails then low temp shut off for solar is needed. Thinking maybe 40amp remote bulb thermostats set to shut off PV strings if box drops below 35f?
My friend a neighbor is setting up a very similar system to upgrade his 4year old lead acid wind assisted system. No more wind. Same battery bank and box. Samlex 2422 inverter charger. Changing panels from 8-100w and EPEver 60a to the same PV as mine.
Any input is appreciated.
My project:
