Anthony Garcia
- Nov 11, 2021
- 4
i am new to this solar power thing... so i need some assistance in picking rigid panels that will work with a Bluetti EB70. Im basically trying to make a barn on my property offgrid power using a portable power station. The station will stay at the barn full time (except for trips). I will typically use two 40W LED bulb for 3 hrs a day. Im thinking the EB70 at 700Whr should take care of that. But i would like it to be recharged with roof mounted rigid panels. I would like to use as close as possible to maximum charge potential of the EB70. it seems that's 200W input? Its not clear on their web site. I dont want to use the portable 200W bluetti panels, since they are not waterproof.. ie. when snow is on roof. But from what im reading on this forum you have to match other specs to the unit, Voltage, Amps? A simple explanation of the math would be helpful.
There's lots of choices and confusion for a newbie. Not sure if i need 12v or 24v? So some assistance would be greatly appreciated, so i can make a purchase.
here are a couple of rigid panels on amazon:
any thoughts on wich one these or others would work?
Or would i be better looking at two 100W? if so, in series or parallel?
RICH SOLAR 200 Watt 24 Volt Moncrystalline
RICH SOLAR 200 Watt 12 Volt Moncrystalline
