@PsychoticEpisode : That's a starter system?? Ouch! $1300 + $1600 in batteries? That's a pretty darned steep entry price for most people.
@mark46808 : The power audit is a starting point for a reason, and it provides 4 vital things you'll need to know for building a system. You start with what you have/need now, and then add in the "Like To Have's" later and see where it all comes out. What you'll get out of the Power Audit:
1: It tells you how big your inverter needs to be so you don't waste money on something too small or way too big.
2: It tells you how big your battery bank needs to be to run your stuff, both amperage and wattage.
3: It tells you how much solar array you'll need to recharge that battery bank in a reasonable amount of time.
4: Provides a skill base that you'll use over and over again as you move up from the small starter system you have now to larger and more powerful systems.
As for the AIO systems like what
@PsychoticEpisode mentions, they are MUCH easier to deal with as they take most of the guesswork and parts picking out of the equation. They're usually scalable, pretty cost effective, and pretty available online. I know that you're working with a very limited budget so definitely go with used solar panels, you can't beat the price/watt.
Understand that with small starter systems like what you've picked up so far, you're probably going to end up throwing it all in the trash in the future as you learn more and get more practice. We call that "Tuition" and I've spent a goodly amount of money on it myself.
The system voltage is really important for inverter sizing. If you're only doing about 3Kw you have the options of 24v and 48v AIO's. If you want you
COULD go with a 3kw 12v inverter, but that's a LOT of amperage to deal with. If you're looking for a larger system than that you'll need to step up to 48v. The big advantage of 48v is that it uses smaller fuses and wires, the big disadvantage is that every time you want to upgrade the battery bank you have to get 4 batteries* at a time.
Definitely peruse the forums and the FAQ section in particular for the basics on how the different systems work (PWM vs MPPT, How to Power Audit, terminology, etc) to start getting a basic understanding of what we're all talking about. Doodles and notes are always a good idea, and if you're doing research and something confuses you, ask! We're here to help.
