Newbie in need of help. Best setup for my EcoFlow Delta Pro solar system.
ChadP
VA
Current set up is one delta pro power station, 2 delta pro extra batteries and a EcoFlow dual fuel generator with 3 400 watt EcoFlow portable solar panels. I got a free extra battery because Home Depot messed my order up. So I haven’t used the dual fuel as I can only connect the 2 extra batteries or 1 extra battery and the dual fuel generator. We are going to do full time RV living. I am thinking of purchasing another delta pro power station and dual fuel generator so I can have 2 power stations with each having an extra battery and a dual fuel generator connected to them. My RV is a 50 amp with 2 AC’s but I don’t understand the power hub and also people talking about transfer switches. Is this a doable set up? Thanks
Will I need the power hub and a transfer switch for this set up. Not planning on running anymore solar panels will just keep the 3 400 watt panels running to one power station in series and I’m pulling about 950 to 1050 watts for about 2 hours then 400 to 800 watts for about 3 hours where we are currently set up. Thanks in advance for any help!
Only reason I would need the 240 is to run both AC units at same time. If I don’t have the double voltage power hub, how would I connect the two delta pro power stations together with each having an extra battery and dual fuel generator? Is that possible to do without the double voltage hub?
