chrisski
Solar Boondocker
- Aug 14, 2020
- 5,179
Just my thoughts, and not worth much. Does it look like it could have burned from the inside out?
Seeing some battery disassembly videos, I cringe when I see the wire size that manufacturers put from the terminals to the cells. However these terminals are connected are important also. The lug should lie on flat on the terminal for conductor to conductor contact and not have a steel washer between them. I also believe that a continuously rated for 45 amps of output is not put to that test very often, for very long. Seems like the response you got was beating around the bush like, “It’s rated to 50 ah continuous, but you really didn’t expect more than a couple minutes at that did you?” Also there is whatever amps the motor spiked to, like frequent increases in speed or going over debris.
Would be interesting to see an after picture of the terminals that were hooked to it.
