Dave S
- Nov 3, 2022
- 13
Hi. I took two 12 volt batteries, wired them in series. Produced 26 volts. Hooked it up to a 24 v inverter. Then I put an AC device on inverter that draws 200 watts. When I took an amp reading. meter says I draw 16+ amps. 200 watts at 12 volts should be 16.6 amps...I would think 200 watts at 24 volts would be 8.3...Why is my reasoning wrong? Thanks
