Oak_Sandalfoot
- Mar 16, 2022
- 33
**********Updated 4/22/22**********
Greetings solar community,
I need help setting up my first PV system in my Schoolbus RV conversion. I have the following components:
* PV array (3 x 250w in parallel)
-max VoC: 50.9, Isc: 6.2A (Sunpower)
*2500w PSWI (Reliable)
*100/50A MPPT SCC (Vic.)
*18A DC to DC charger (Vic. Orion)
*Lynx Power In busbar (modded to be a Fuse holder as well) (Vic.)
*412ah LiFePO⁴ battery bank (2 x 206ah wired in parallel) (SOK)
*DC fuse block and AC breaker box. (DC: 100a Blue Seas, AC box: N/A)
*Master disconnect wired at positive output terminal of the Lynx
*Shunt (Renogy) for BM (Renogy) at negative output of Lynx
*Fuses:
-Inverter: 400a mega
-SCC: 60a mega
-Dc to DC charger: 60a (lynx), 50a terminal fuse (starter battery)
-DC fuse box: 100a mega fuse
-AC breaker box: N/A
-Lynx positive output cable to battery: ANL, Mega or T fuse?
I've been working countless hours to learn all of this stuff on the internet from rock bottom/scratch with ZERO prior electrical experience. With the vast amount of information, seemingly infinite variations of design, conflicting viewpoints, my 'noobability', and the inability to discuss the issues face to face with a knowledgeable human, the whole process has been very challenging. I am proud of how far I've progressed in the past two months from the drooling idiot at the solar warehouse to someone who can actually read through a solar forum and understand the language and glean information; however, I am not too proud to know that I still don't know sh*t and I need help!
When I dip my head into that huge barrel of questionable apples, these are a few that float to the surface:
1)Can the following devices (going into the Lynx Busbar/fuse block) all be wired with 6awg?
*Orion DC to DC 12v/18a
*50a scc
*DC fuse box (blue seas w/ blade fuses)
-100a, 150a max (I think)
2)Inverter to Lynx cable gauge? (Short run <2 feet)
*1/0, 2/0 or 4/0 awg?
3)Lynx to battery cable gauge? (Short run)
*1/0, 2/0, or 4/0
4) I have some insulated 6 awg in two different types: one is like 50 strands or more, and the other is exactly 7 strands. Which is preferable to my application? Basically, coarse or fine strand cable? (I already learned that solid is not recommended for mobile applications)
5) Orion DC to DC 18a charger:
*Can it be wired to either the starter battery or alternator, or does it have to wire to both (I'm confused because none of the many, many install videos on 'the Tube' ever wire directly to the alternator.)
I'm assuming, based on extensive thread surfing, that connecting to the starter battery in effect connects to the alternator as well?
6) Is it advisable to put a dual pole DC breaker between the solar panels and the SCC? If yes, then what Amperage breaker)
7) Can the Inverter and SCC be grounded on the DC fuse box instead of the chassis? (Grounding to chasis is viable option if not)
8) What fuse (???A) between main positive of Lynx bus and battery bank? ANL, Mega, T Fuse?
9) Any recommendations or comments on my setup just based on the components listed?
Thank you in advance to everyone who contributes their time, money, and energy to make these sorts of 'far-flung' endeavors possible for a noob like myself.
Cheers,
Oak Sandalfoot
IG: Dumpstarsdivingbus
(Skoolie build and Dumpster diving)
*Fuses:
-SCC: 60a mega
*50a scc
*1/0, 2/0, or 4/0
Cheers,
Oak Sandalfoot
