Hello,
I am trying to setup my first solar circuit, I have read a lot of forums, and advice topics but am not sure I am on the right path with my diagram. Please look at it and let me know of changes I need to include or tips! I've attached the diagram I drew. =)
Here's the rundown if the diagram isn't understandable.
> (12v 60w PV Panel) runs into a (12v 20A PWM Charge Controller) which hooks up to a (12v 20ah/20 hour lead acid battery) & on the load side of the controller I will run the cable into a toggle motion detector 'for when I walk out the patio door' to trigger a photocell switch to determine if it's day/night and if it's day it'll turn on the 12v 19w DC Pond Pump, if it's night it'll turn on the four 12v 3w LED lights, when I return back into the house the motion switch will trigger off the circuit.
Thank you!
Thank you!
