Rednecktek
Solar Wizard
So I have plans to utilize some 280Ah EVE cells, a JBD SmartBMS 120a, and a Giandel 1200w inverter w/ 20a PWM to make a 3-layer box build. The idea is that the batteries would sit in the bottom with a couple heating pads on a digital controller, then the next deck up would house the BMS, inverter, shunt, fuse block, and all the wires. The top layer would be the space where you interact with the stuff with the 120v outlets, USB outlets, meters, etc as well as the MC4 connectors for plugging in the pair of 150w panels in parallel that will be with the unit.
I'm still working on the details of the exact wiring diagram as (is visible in the doodle) it gets pretty tangled in there pretty quick and still need to decide on what make & model of case will fit all the parts with enough room for the inverter and BMS to breathe.
What all am I missing y'all?
