Silentpower
Over Rated
Never heard that before!The batteries work by "breathing" and exchanging oxygen. So anything that inhibts the carbon would also likely inhibit the batteries primary function.
Just wanted to let you know that your post save me some money and push me to register to this site as I was about to toss out my adapter thinking that it was a crap. The only question left for this setup which I am about to perform during the weekend is how did you setup your controllers in regard the battery capacity (ah). If I am going to use both to charge a single 24v 405ah bank; should I set both to 400ah? Please provide info. Thanks a lot for your post.I finally have my 2 Epever charge controllers acting in parallel together using the PT-ADP-PORT! There is both good and bad here, and the bad starts with a very poorly written manual that skips the most important step of all, it also includes a bunch of unnecessary steps. The software that is available is abysmal, the one device that I really like namely the MT-50 does not work when these controllers are connected in parallel, this is a real shame I was hoping to see 200A on the screen along with an overview of the entire charging system. However, the MT-50 is still useful as you can still use it to configure the controllers individually while the controllers are not connected together. This is a far better approach than using the god-awful software.
Just a note on the god-awful Epever windows software, if you ever get the message on the com port (Doesn’t exist or not yet set up), and you will get it if you simply use the Add Station button. You need to go into the Port Config menu, Port Configuration, and hit the Add button on that screen with the correct port selected!!!! I’ve probably waisted 2 hours of my life installing drivers and playing with port setting in device manager only to find out its their shitty software and not my settings! ARG! I hope I save at least one of you from pulling your hair out.
The good news however despite their manual suggesting to use the windows software you can actually make this work without the software and only use an MT-50 for setting the appropriate settings for the controllers. Just remember for the MT-50 to work you have to disconnect all the controllers from each other and from the PT-ADP-PORT. Then set all your controllers with exactly the same settings. Plugging in the data cables PT-ADP-PORT Master --> CC1 --> CC2 --> etc (also the ports on the controllers are the same so it doesn’t matter which one goes to which) initilly this will make no difference to the controllers behavior. They will continue to function as they did independently. So, here is the trick, the one piece the manual neglects to mention!
You need to power cycle the controllers!!! So, Isolate the solar panels by switching them off. Connect all your data cables, then Isolate the batteries also. The controllers are now powered down. Reconnect the batteries, and switch on the solar also. Monitor the Amps for each controller and although they won’t be exact, they will both step up and down as it finds the correct point then once that’s found they will remain normally with in <1A of each other. The behavior without this function will be that one controller will be providing most of the current and the other very little. It appears that the PT-ADP-PORT does a good job at keeping the controllers balanced which also helps with the heat transfer off the controllers themselves as mine tend to get quite warm. Previously one would get quite warm and the other would be just sitting there basically idle. So all in all its working as intended, the manual and software sucks but if you follow what I have written above then its possible to get it to work.
PT-ADP-PORT
https://www.ebay.com.au/itm/PT-ADP-PORT-PT-Adapter-Adjust-The-Epever-Tracer-AN-Controller-In-Parallel-Use/352895361313?ssPageName=STRK:MEBIDX:IT&_trksid=p2060353.m1438.l2649
Day | Source (kWh) | Load (kWh) | Batt Out (kWh) | Voltage | Dod | ROI |
1 | 2.36 | 1.23 | 0.59 | 15.55 - 13.35 | 29% | $0.38 |
2 | 5.48 | 6.86 | 2.70 | 16.14 - 11.29 | 65% | $2.46 |
3 | 8.79 | 7.39 | 2.89 | 16.23 - 12.80 | 46% | $2.59 |
4 | 10.57 | 8.40 | 4.16 | 16.27 - 12.81 | 46% | $2.89 |
5 | 13.23 | 7.50 | 1.07 | 16.43 - 12.53 | 52% | $2.63 |
6 | 2.07 | 5.62 | 3.57 | 14.97 - 12.71 | 30% | $2.01 |
7 | 8.05 | 8.90 | 5.26 | 16.28 - 10.60 | 76% | $2.79 |
8 | 11.79 | 9.31 | 3.44 | 16.24 - 11.25 | 67% | $3.24 |
9 | 13.90 | 11.50 | 5.62 | 16.30 - 10.31 | 80% | $3.82 |
10 | 14.66 | 11.31 | 5.62 | 16.31 - 10.33 | 80% | $3.76 |
11 | 14.18 | 10.75 | 5.19 | 16.25 - 10.56 | 76% | $3.74 |
12 | 14.57 | 12.33 | 6.06 | 16.27 - 10.54 | 76% | $4.05 |
13 | 4.75 | 4.42 | 1.26 | 15.57 - 12.98 | 35% | $1.52 |
14 | 11.74 | 10.37 | 6.08 | 16.29 - 10.96 | 71% | $3.40 |
15 | 7.99 | 7.53 | 2.50 | 15.84 - 12.18 | 49% | $2.65 |
16 | 8.99 | 7.76 | 2.99 | 16.22 - 11.88 | 58% | $2.73 |
17 | 14.70 | 11.16 | 4.33 | 16.26 - 12.40 | 51% | $3.55 |
18 | 15.19 | 9.54 | 2.79 | 16.26 - 9.76 | 87% | $3.37 |
19 | 10.26 | 9.31 | 3.48 | 16.27 - 13.02 | 43% | $3.27 |
20 | 11.25 | 7.14 | 0.90 | 16.30 - 13.37 | 39% | $2.51 |
21 | 6.80 | 10.70 | 5.01 | 15.00 - 12.33 | 36% | $3.79 |
22 | 7.76 | 6.18 | 1.70 | 15.80 - 11.29 | 60% | $2.21 |
23 | 10.58 | 7.14 | 1.59 | 16.21 - 10.79 | 72% | $2.51 |
24 | 11.84 | 8.13 | 3.15 | 16.25 - 12.55 | 49% | $2.87 |
25 | 7.65 | 9.67 | 5.57 | 16.21 - 12.45 | 50% | $3.42 |
26 | 7.40 | 7.64 | 2.16 | 15.77 - 12.88 | 39% | $2.69 |
27 | 11.12 | 10.69 | 4.48 | 16.21 - 12.43 | 50% | $3.78 |
28 | 12.97 | 12.63 | 5.80 | 16.22 - 12.36 | 52% | $4.37 |
29 | 14.67 | 14.15 | 6.76 | 16.19 - 11.09 | 68% | $4.97 |
30 | 10.07 | 9.71 | 3.88 | 16.05 - 10.55 | 73% | $3.48 |
Day | Source (kWh) | Load (kWh) | Batt Out (kWh) | Voltage | Dod | ROI | |||||
1 | 13.72 | 10.57 | 3.62 | 16.18 - 12.85 | 44% | $3.74 | |||||
2 | 12.07 | 11.20 | 4.63 | 16.15 - 12.81 | 45% | $3.94 | |||||
3 | 2.88 | 5.50 | 3.32 | 14.64 - 12.33 | 31% | $1.91 | |||||
4 | 4.46 | 2.44 | 1.36 | 15.98 - 10.78 | 69% | $0.76 | |||||
5 | 9.78 | 10.84 | 3.77 | 16.13 - 12.75 | 45% | $3.83 | |||||
6 | 5.43 | 6.03 | 2.40 | 15.98 - 12.73 | 43% | $2.09 | |||||
7 | 9.23 | 10.41 | 4.81 | 16.12 - 12.22 | 52% | $3.65 | |||||
8 | 9.66 | 10.15 | 3.07 | 15.90 - 11.85 | 54% | $3.48 | |||||
9 | 12.29 | 11.37 | 4.81 | 16.18 - 12.23 | 53% | $3.98 | |||||
10 | 11.36 | 10.29 | 4.01 | 16.15 - 12.65 | 47% | $3.64 | |||||
11 | 4.72 | 2.70 | 1.17 | 16.08 - 13.23 | 38% | $0.91 | |||||
12 | 9.61 | 10.46 | 4.73 | 16.15 - 12.68 | 46% | $3.61 | |||||
13 | 11.80 | 10.87 | 4.60 | 16.15 - 12.59 | 48% | $3.81 | |||||
14 | 10.72 | 12.17 | 5.98 | 16.18 - 10.98 | 69% | $4.14 | |||||
15 | 11.67 | 11.30 | 4.45 | 16.20 - 11.08 | 68% | $3.98 | |||||
16 | 10.91 | 10.85 | 5.43 | 16.27 - 12.30 | 53% | $3.65 | |||||
17 | 12.76 | 12.49 | 5.48 | 16.34 - 12.64 | 49% | $4.28 | |||||
18 | 11.15 | 10.89 | 3.95 | 16.30 - 12.93 | 45% | $3.69 | |||||
19 | 11.23 | 11.82 | 4.99 | 16.30 - 12.72 | 48% | $3.98 | |||||
20 | 9.66 | 11.03 | 4.59 | 16.12 - 10.68 | 73% | $3.86 | |||||
21 | 6.77 | 6.39 | 2.77 | 16.24 - 11.63 | 61% | $2.29 | |||||
22 | 7.74 | 7.05 | 2.82 | 16.20 - 12.92 | 44% | $2.33 | |||||
23 | 6.94 | 7.58 | 3.78 | 16.31 - 11.14 | 69% | $2.72 | |||||
24 | 15.23 | 13.97 | 5.51 | 16.34 - 10.85 | 73% | $4.88 | |||||
25 | 8.78 | 7.58 | 3.09 | 16.37 - 12.99 | 45% | $2.50 | |||||
26 | 9.07 | 10.12 | 4.70 | 16.38 - 12.75 | 48% | $3.52 | |||||
27 | 7.22 | 6.13 | 3.58 | 16.24 - 12.94 | 44% | $1.96 | |||||
28 | 9.60 | 7.55 | 3.75 | 16.37 - 13.14 | 43% | $2.53 | |||||
29 | 11.58 | 9.56 | 3.28 | 16.39 - 13.31 | 41% | $3.28 | |||||
30 | 12.81 | 10.01 | 2.39 | 16.41 - 13.26 | 42% | $3.37 | |||||
31 | 14.89 | 15.20 | 4.87 | 16.49 - 13.11 | 45% | $5.28 |
I'm buying Lifepo4. Soon.
Sounds like you may have got a bad batch of cells, they are made in china, or the electrolyte wasn't mixed correctly in that bank. Allowing the voltage to go below .95v will destroy them as they will delaminate.
Well I'm on the inside, but its the most livable leper colony in the world!!
Well I'd be interested in taking them off your hands if your not asking too much for them
I'll keep your offer in mind!
Yeah no worries, well good luck!!
Thanks great news, glad to hear it.he's agreed to a full refund
I'm going to 24V first, but thanks.If you're after a 48V inverter, or two
I thought it best not to go 12V.
It does mean that I have to buy new inverters each time I change voltage,
Yeah I wish Inverters were as flexible as charge controllers are, but the cost of doing that is most likely quite prohibitive and its a limitation of the FET's used., I had to buy a larger inverter.
Month | Source (kWh) | Load (kWh) | Batt Out (kWh) | Voltage | Cycles | ROI | Avg Load (kWh) | Avg Source (kWh) |
January | 160.11 | 146.95 | 67.16 | 16.28 - 12.44 | 11 | $50.06 | 4.74 | 5.16 |
February | 163.08 | 153.85 | 88.72 | 16.52 - 10.12 | 11.23 | $48.93 | 5.31 | 5.62 |
March | 121.42 | 110.57 | 61.92 | 16.37 - 12.44 | 11.12 | $36.97 | 3.57 | 3.92 |
April | 193.88 | 184.73 | 108.96 | 16.58 - 9.75 | 13.83 | $58.51 | 6.16 | 6.46 |
May | 300.24 | 266.04 | 126.48 | 16.79 - 9.64 | 21.62 | $86.71 | 8.58 | 9.69 |
June | 305.36 | 264.98 | 110.6 | 16.43 - 9.76 | 17.04 | $91.46 | 8.83 | 10.18 |
July | 305.76 | 294.5 | 121.71 | 16.49 - 10.68 | 15.76 | $101.56 | 9.5 | 9.86 |
August | 355.59 | 314.42 | 112.12 | 16.46 - 11.38 | 14.15 | $107.63 | 10.14 | 11.47 |
September | 269.83 | 262.61 | 94.74 | 16.32 - 11.80 | 12.62 | $89.63 | 8.75 | 8.99 |
October | 90.57 | 85.46 | 29.9 | 16.35 - 11.08 | 4.07 | $29.19 | 8.55 | 9.06 |
