Repro
I had twelve 100W panels that I initially bought to keep mobile for various uses. Mostly for RV'ing and other portable uses. Since I no longer need them in that capacity, I wanted to set them up permanently and get some use out of them. I needed a ground mount and was contemplating building one when I found these ground mounts from Eco-Worthy. They can be found on Amazon if interested.
Here is the Description on Amazon and link:
These are made from very sturdy steel galvanized channel struts and some other hardware. I have channel struts left over and thought I would build them myself. When calculating the hardware costs, it was much cheaper to buy these ready to go units from Eco-Worthy, even though I had left over channel struts. I mounted them to deck blocks that cost under $4 each, and they provide 180lbs of ballast keeping them very secure to the ground, yet can be moved if needed.
I bought 8AWG cables and ran them to my Victron MultiPlus II 3000 system. I have two Signature Solar 48v Lifepower rack batteries on that system, and it works great. I use about the top 30% each night, and these twelve panels have them topped off by 1pm each day.
All in all, these ground mounts are very affordable, super easy to assemble, can hold up to 5 panels each of my HQST 100W compact panels. I had so much room left on each side that I had to cut off the excess. I think these mounts are great and you will not get them cheaper. I hope this helps somebody out.
ECO-Worthy Adjustable Multi-Pieces Solar Panel Mounting Brackets Kit System for 1-4pcs Solar Panels
