Nickel strip for 12V 90AH 32700 cells.
Yep. That's about the same as 16awg wire with no insulation, so 18A is doable.
After doing some thinking, would a 24V pack work better? Like a 7p8s setup. Little less capacity but less amps to deal with doing the series connections.
I’m making a portable solar generator. It will include a small 300W inverter and studs to hook up a 1500W inverter when needed. I attached a picture of the exact enclosure I’ll be using.
Check out David Poz on youtube, he just built a battery with these cells and he talks about the nickel strips he used.
I watch his video like twice now. I’m in contact with the eBay seller to get the strips. My main issue is I’d have to stack the nickel strips and I don’t have a proper spot welder.
