I have a pretty specific case for a system I am planing. The electricity price is roughly 0.45USD by kwh here during the day, and goes down in the night to 0.01USD.
So the usual solar system wouldnt work with AC charge timers. Also the charge timer has to be adjusted manually every day at 12:00 when the electricity prices of the following day at every hour is published. So i would set it up to charge batteries always between 0:00 - 6:00 at night, with the option to change those times in case.
Is there any inverter/charger combo that could do that? going the growatt route it wouldnt be possible. unless i install a programmable AC switch - giving the growatt only at specific hours the AC current to be able to grid recharge batteries. which can be risky if the weather is really shabby for a while or during winter. thinking a 400ah battery charging with 50amps, needs 8 hours, not 6. so it wouldnt be able to fix an almost 0 sun production day during night charging.
