There is big difference between your deck and array. Your array will act like a huge sail so it could have a large amount of force from wind trying to pull it up out of the ground. It depends on your exposure to wind, max wind expected, soil type, height and angle of array, size of array, number of posts, etc.2. Does the ground mount need to be UL certified or can I build it like a deck using 6x6 post. The reason im asking is because when looking at the ironridge spec drawings, they require a 7 foot deep hole which is crazy considering building deck is requirement is just below the frost line about 3 feet.
Unless you hire soil engineers and do core samples, no one really has any idea what your soil is like. So I think they have to go ultra conservative and call out 7' deep holes filled with concrete so the weight of the concrete is high enough that they really don't depend much on the pullout force on the soil. If you think about the fact that each panel is held in place by 4 clamps that use a #12 machine screw attached to thin aluminum rails, and that doesn't break or blow away. But if you put 10 panels together suddenly you have to pour 7' deep holes filled with concrete and use 3" schedule 40 pipe to hold it all together. Makes no sense.2. Does the ground mount need to be UL certified or can I build it like a deck using 6x6 post. The reason im asking is because when looking at the ironridge spec drawings, they require a 7 foot deep hole which is crazy considering building deck is requirement is just below the frost line about 3 feet.
I assume the panel upgrade is to get a higher bus rating, but I'm not sure how you would get one rated to allow 14kW. 200A panels are available with 225A busses, but that won't quite get you to 14kW unless you downsize the main breaker. Have you thought about putting in a line tap instead of changing your panel? Depending on the physical configuration of your meter and service panel, that might be cheaper than a new service panel. And then you'd have no limits on how much you backfeed. Or better yet ask your utility company if they can provide those meter heads that have a socket built right into them to connect solar. It's basically a meter head with a line tap built right in. I've seen pictures of them, you basically attach like a heavy welding cable to the bottom of the meter and run it into an adjacent enclosure that connects the AC output from your inverter.1. I will be installing a 14kW grid tied enphase system but that requires me to upgrade my breaker panel. Because of this, do I need to make this a 2 step process before applying for the solar permit. I would replace my main breaker panel with a 200A panel plus maybe install a safety switch between the main service coming in and my new breaker panel. Once this is done, then start the solar permit.
Similar to other comments, for my ground array, I just assumed 'worst case' soil and built to that - so that if I was inspected there would be no problem. Also - kept it 4ft from edge of property - same as for DIY sheds in our jurisdiction.2. Does the ground mount need to be UL certified or can I build it like a deck using 6x6 post. The reason im asking is because when looking at the ironridge spec drawings, they require a 7 foot deep hole which is crazy considering building deck is requirement is just below the frost line about 3 feet.
Are those water tanks? How do they get filled?Here's the finished result using 2" x 10ft galvanized pipe + 10ft universal strut to hold up 20 panels. Been up for 2 winters now - not a single issue as far as wind or movement or strength. I suspect my ballast was way-overkill
Yes - we do RainHarvest as well as solar. All part of 'Off Grid in the City' themeAre those water tanks? How do they get filled?
