That seems risky!
Batrium is designed for an external contactor or shunt trip breaker.
Yep. My usage is a small fraction of the battery capacity, and I'm keeping the cells between 3.50-3.92. I'm okay with this on a temporary basis.
I'm using this breaker:
Midnite Solar MNEDC250RT, 250A 125VDC Panel Mount Breaker has the Remote Trip feature that allows it to work with Midnite's Battery Disconnect Module and the Rapid Shutdown System. MNEDC250RT
www.altestore.com
Looks good. Thanks for that. The relay they mention on their videos is not available, so I've been looking for another. I'll probably get that one.
I also plan to implement hard shut-offs through the expansion board. In this fashion, the MPPT and inverters are shut off not via software but with their control relays.
With the breaker in place, that will be 3 levels of safety: software cut-offs, hardware cut-offs and the contactor.
As I was composing this email, Something weird has started happening. Cell #14 is jumping around. I've been discharging continuously for over 24 hours with the MPPT off conducting a discharge test, but #14 alternates between 3.73 and 3.86V:
I have had auto-level off since I wanted to test how they tracked with nothing more than the ~40-80mA of active balance. They've been extremely consistent at .01-0.2V deviation. When I saw the .14V deviation out of nowhere, I reactivated auto-level, and it immediately came back down to 3.72 from 3.86. #14 has the jumper wire on it, and I deliberately checked that all those wires were secure in the connector. I'll do it again next time I'm on site.
On the chance that the activation of bypass corrected the error, I've enabled it to activate at a 0.05V difference all the way down to 3.00V/0% SoC.
Here's what the discharge test looks like so far:
Up until I saw the voltage wonkiness, I was very pleased.
