NMEA battery boxes for lifepo4 prismatic cells? 32 eve 280ah cells
nebulight
Las Vegas
I'm considering buying 32 EVE 280ah cells for battery storage for my solar install in Las Vegas. NV Energy will provide up to $3000 if I switch to TOU and $1500 if I stay on a normal rate. I'm consider switching to TOU and sell back to the grid from the battery at the higher rate and recharge the following morning and/or buy back from the grid at night at a much lower rate.
Since I'm going to be getting a credit from the utility, I want to make sure the battery box is to code. I've seen a lot of toolbox installs and just basement floor installs. Has anyone found a good quality battery box that could be used for a floor mount install? this isn't an every day item so you can't just go down to Lowes and look at it to see if it's high quality so I'm worried about buying something online and having it show up cheap.
Thanks in advance.
