Got this panel, I believe 200 watts, nothing on it indicating a brand. There are 4 flat contacts sticking out the back, I'm just trying to figure out on how to wire it without burning anything. Any suggestions?
Agree with @Bud Martin.Posting good clear pictures will be a great starting point.
Voltage is just based on number of series cells 0.63v Voc per cell, 0.52v Vmp per cell @25 degs C@RCinFLA thanks so much! Just measured the voltage, from 2 outer tabs 42v, 14v and 28v on second and third tabs. Looks like a 300 watts panel then? Which junction box should I buy then?
Size ID | Size mm |
M0 | 156.00 |
M1 | 156.75 |
M2 | 156.75 |
M3 | 158.75 |
M4 | 161.70 |
M5 | 165.00 |
M6 | 166.75 |
M12 | 210.00 |
You need the right number of tabs - e.g. a 4 tab connection 'type' in your case AND diodes that can handle the amps.It's exactly 156mm! 8.7amp? How do I figure out which junction box to buy?
