wherethesundontshine
I've got a Sol-Ark 15K that I'm monitoring over RS-485 using Solar Assistant
During the day (ie when we're getting some solar) the Sol-Ark shows the power flows from the panel and grid to the house on the screen of the unit and I'm able to pull that data live via Solar Assistant.
However once solar production stops, the screen of the unit just says "OFF" and I don't see any power information there or via solar assistant (though to be clear, the house is still powered fine via the grid pass through).
Is there any setting I can change to be able to always see the house usage data, even when its just passing through the grid power?
