…or the speech center of the brain having been burned awayMay have to do with thicker skin on fingers.
was it lead acid? or lithium? (or some other chemistry??) I think the difference is in the ability of the battery to dump its power similar to a capacitor. the LiFePo4 batteries can dump power at insane rates. the CALB's I am using even though they are used units originally had the ability to dump at 600 amps for a 10 second pulse.... whats that equal for a millisecond? on a sweaty salty forearm? I have no clue, but that coupled with a full charge as all had been top balanced all of their voltages were at or above 58 volts all being freshly top balanced so I could add the new pack. needless to say it was enlightening.I'm amazed at these reports of getting shocked by 12 and 48 volts.
I've got a 60v battery and had 3 different people touch it both wet and dry. Two fingers in the same hand to positive and negative. None of them reported anything.
in this case it was forearm by the elbow to forearm by the wrist. so short and sweet.. or sweatMay have to do with thicker skin on fingers.
And spreading resistance, longer length of arm had more current flow deeper.
Which is presumably why anyone touching a van de graaff generator dies instantly?Capability of battery to deliver amps will have no influence on the shock you get. It is only voltage/body_resistance) that matters.
You would think they would regulate those things a bit better.Which is presumably why anyone touching a van de graaff generator dies instantly?
Actually a very good video game also..Well here are my own "sins"
"Sins of a Solar Empire"
(Not promoting any game here, just thought of it as an apt title) Quite embarrassed to admit, but so far I have had: Accidentally shorted the positive and negative of one of my 12v batteries. Got sparks that jolted me back to my senses (pun intended). Luckily the battery seems to be fine...diysolarforum.com
I did the same thing when push starting a go-kart. My arm touched the top of the spark plug and got a few decent shocks before I pulled it away. Just felt like a very strong electric fence.Not a shocked by a battery story but:
Once upon a time when I was around 10 years old, a friend of mine acquired a used go cart. It didn't have the original centrifugal clutch and the one he had was to small to fit the motor so we had the bright idea to file down the motors shaft to fit the clutch.
To accomplish this we would take turns holding a file on the shaft while the other held the throttle open to rev up the engine. I was the first to hold the throttle open and while doing that my arm touched the top spark plug and in those days the plug wire didn't have a boot so I was indirect contact with whatever voltage was flowing to the plug.
From the moment of contact I was in some sort of dream state and wasn't fully aware of my surroundings. I don't know how long I was in contact with the plug, but do remember my friend pulling my hand off the throttle and me coming out of my electrically induced dream.
I didn't seem to have any ill effects at the time. I'm 60 now and for the last 20 years I have had all kinds of nerve related problems. I don't know if it's related but it wouldn't surprise me.
You may be on to something there. These guys all work on heavy equipment.May have to do with thicker skin on fingers.
Hahaha, see above!…or the speech center of the brain having been burned away
Lithium, not lifepo4. But, smaller capacity. It's a power tool battery. Short circuit current shouldn't factor into how well it can pass current through anything. Current flow is volts/ohms. Current flow (amps) is the result.was it lead acid? or lithium? (or some other chemistry??)
