Alpatron77
I am new to solar and backup power, looking for recommendations to run a backup single sump pump, emergency backup only. Is it possible to run the sump pump directly off of my 110 outlet and have the system kick over once the power is out? Also do I need a transfer pump switch relay with my inverter?
No solar for this setup.
What battery charger and batteries and other equipment would you recommend for setup?
I was planning on going with a minimum of 3-4 12 volt 100 amp each batteries. This is system might be needed once or twice a year with bad storms.
Also i understand that the inverter will have a constant draw on the batteries. Can I keep this system on 24/7 or will need a cutoff switch and routinely charge the system?
Recommendations please
Inverter:
Xantrex xpower plus 3000 watt modified sine
Peak surge 5000 amps
Sump Pump:
Liberty model 287
1/2 hp 8amp 120 volt
Starting amps 23
Inverter:
- no built in charger
Sump Pump:
Liberty model 287
Starting amps 23
