Justins311
- Jun 14, 2022
- 10
So I'm pretty mechanically inclined (engineer) and have built several LiFePO4 ebikes @52V, but am learning electrical and I've never built my own battery pack. Starting with a 12V solar/lithium build for my motorhome and have been learning from here and Will's great youtube channel. Here is my build and LOTS of associated questions, I appreciate input on any of them!
Build
1) 12V LiFePO4 battery. Planning to order:
a) (4) EVE LF280 280Ah 3.2V LiFePO4 at $580 + tax = $625 shipped
b) (1) 4S 12V BMS w 24" leads and crimped ring terminals = $165 shipped
c) Foam, allthread inside a plastic battery box
2) Distribution/charging:
a) Victron Multiplus 12V/2000w/80a charger/converter/inverter [already purchased]
b) WFCO 8955PEC for 12 & 120V power distribution [came installed in the coach - REMOVING CHARGER/CONVERTER PORTION]
c) AiLi 500A Battery Monitor w/ shunt installed at negative battery [already purchased]
3) Solar/MPPT: Rich Solar 400W 12V kit w/ 40a MPPT solar charge controller
Questions
1) BATTERY: I find wildly varying prices on EVE cells, Docan power seems to have the best price and was recommended. I was planning to get a server battery but 400ah is all thats currently available @$1500 which is way more than I need/can afford right now. Are there any other options or is the 280ah build @ about $800 all built my best options? Anything inbetween? I'd prefer a pre built solution w case but haven't found anything in the 300ah/$1000 range which is my max budget
If I do end up building it, I'd prefer a prebuilt case like SOK offers. @$1029+ shipping for 206ah it seems like I get way more for my money DIY. I'd spend a little more for a decent case but can't seem to find any offered. The Ampere time 200ah @ $710 seems interesting and affordable but I dont want to cheap out and have read mixed reviews.
2) Converting/Battery CHARGING:
a) From research it appears I need to disconnect the charger/converter from the WFCO. The WFCO has a built in/add on T30a transfer switch to transfer between my Onan generator and shore power inputs. I originally assumed I could remove this transfer switch and use the Multiplus, but it appears the only transfer the Multiplus compact can do is between 12V DC and a single 120V input (from my T30). So I need to feed keep the T30 and feed into the Multiplus input, correct?
b) Random question - I have a 52V/24ah ebike battery I'll be carrying with me on most trips. Rather than use the 52V satiator charger I own, is there any way to integrate it into my Multiplus system as extra capacity? It would be 104ah extra @12V if I could find an economical way...but the Multiplus external battery charger is 12V so I think I'm SOL. Will the Multiplus at least use the small 12V vehicle starter battery as extra capacity, or is it just charging it? Thoughts welcome.
c) Do I NEED any other monitors to be safe? I'd love the Victron Smart Shunt but its seems like an extravagent 200 bucks I dont need to spend when I'm already topped out on my budget. If it'll be unsafe and adds safety switches to the charging I'm open to it, but will the AiLi and an alarm be adequate?
3) MPPT Charger: I would love the Victron 30a MPPT w bluetooth which I could make work for my budget @$220, but it leaves no room for growth and is probably undersized for 400W panels @33a. Victron doesn't seem to offer a 40a so I'd have to jump all the way to a 50 amp version @$323 which means I'm spending twice as much as the Rich Solar. A 3rd option is the Renogy 40a also at $160 - is this a better option than the $160 Rich Solar 40a MPPT?
If you read thru all this and can offer any input this NOOB appreciates you!
Build
Questions
