Stryker777
I'm getting ready to purchase our first inverter and large battery bank for our home. I'm looking at the 18kpv with 3 of the pro wall mount batteries. This will be feeding our home with an estimated daily usage of 34.6kw. I have a max 12kw of solar on my array, 30 400w bifacial panels. I'm not counting the bifacial benefit. Unfortunately, we have a very power hungry electric furnace that I won't be able to feed by inverter power and is not in my calculations. If power fails, our home can be maintained with 2 1500 watt space heaters. I've read that the 18kpv has grid passthrough. Does that mean I can configure it to use grid to supplement the inverter to feed the furnace when the grid is up? Or, do I need to tap the grid for the inverter, connect the grid terminals with a breaker disconnect and configure the 18kpv to feed back to the grid tap for my breaker panel? I can still add a transfer switch and connect the load leads for when the grid is down. I'm just having trouble finding what the grid passthrough is really capable of.
Thank you for any and all input! This will be my first home setup.
