I have a rheem hybrid (heat pump) electric water heater (65 gallon tank). I would love to run it off my dedicated loads panel (my storedge system provides me with 5kw continuous backup power) but the heating elements in it seem to be 4500 or 4800 watts so that is a definite no-go. There is another model by Rheem that seems to only need a 15amp breaker (PROPH80 T2 RH350 D15) which would indicate maybe a 2800 watt element or so. Does anyone know of anyone with any experience with these? I figure my options for running this off my solar include 1 (the nuclear option): an entire second system dedicated solely to my water heater. Ouch expensive. 2) Figure out if I can get my hands on the elements for the other model (or some universal low wattage elements) and see if they even will work with my water heater 3) See if I can fool my water heater into not using the elements at all (ideal since I only want it running the heat pump, not the wasteful resistive heaters). If anyone is curious, I normally run my water heater in heat pump mode only (~750-800 watt surge followed by about 400 watts until it shuts off) which cools my garage and keeps it nice and dry. The two times when the water heater ignores my settings and turns on the elements is when the tank is flushed (or perhaps when the water falls below 90 degrees?) and during startup from a power outage while it cycles everything on/off presumably to test itself.
