D
Deleted member 3614
Guest
Off-grid living in the UK is an unusual experience. Finding water and gas is almost near impossible plus the weather can be terrible for weeks on end.
So what does this have to do with solar power? After fitting refillable gas bottles I soon found that finding a filling station who sells gas (LPG) was going to be hard, they are being removed at a shocking rate so running the heating in the winters months started to cause me a few issues.
I knew my motorhome has a two rated insulation rating with three being the highest, to keep the van at 22 degrees the gas would need to be on setting 4 and 6 being max which is would the gas within a week, so I set out to find and fix drafts and made a new bulkhead that closed off the cab area. The cost of this with insulation and wood was about £50, when looking closely at the van I found many cost-cutting measures used by the company who built the thing, so I made a few changes. Adding a door curtain instantly made a difference on its own.
What this did to the heating was interesting, I could run the gas at setting 2.5 with the weather outside at freezing cold at 22 degrees. this extended the gas bottles to almost 2 weeks which saves £8 per week.
Was so shocked when I bought a tiny halogen heater, this heater cost just £16 has 3 heat setting 400, 800 and 1200 watts, I thought would this work on a cold but sunny day and would it work on the inverter, yes it did, in testing with the solar panels tilted the amps from the panels was more than the heater on 400 watts and the temperature was just over 20, this has extended the gas bottles by around 3 hours per day, this tiny heater managed to heat a large 7.2 m motorhome.
So good insulation is a starting point which then helps gas and power use. If you try and heat something that lets in drafts, you will be wasting money and power.
