Hello!
Does anyone know the port/connection type that DALY BMS uses for their NTC plug? I cannot get my BMS to turn on, and it did not come with a temp sensor which from the posts I've found seems to be needed.
Here's what I have so far:
-I have DALY 4s 12v 200A BMS
-My NTC port is 3 pin, which seems identical to the other photos of folks' DALY BMS on this forum.
-10k thermistor of type 3950 may be the correct sensor for my bms (based on a couple of threads here)
-Thermistors are a 2-pin component.
-One person commented that their thermistor was only attached to the 'right two' pins of their NTC port. (https://diysolarforum.com/threads/r...12v-100a-bms-have-question.16578/#post-209427).
-the connector may be of JST GH 1.25 style (someone stated this is the connector style that overkill BMS uses for the temp sensor)
Thanks!
-visually, the connectors I have look to be this style.
I am thinking I could get a 10k thermistor and a 3-pin JST GH 1.25 to make this all happen, but I would greatly appreciate any info from someone more knowledgeable than myself on this matter.Thanks!
