Hi. I have an off-grid cabin which is currently running off of 1800W of solar and am using 4 of the BattleBorn 100ah and find that this is more than ample for my needs up there and gives me a couple days of autonomy with one or two critical loads. Normally I would winterize the place and disconnect the BattleBorn batteries (for obvious reasons) in the winter as it can reach -30c up there. I would like to be able to have some remote monitoring up there, or at least the ability to quickly get the place up and running when I go up in the winter though.
I notice that the LTO cells are coming down in price and can be charged far below 0 degrees so I figured I would build a smaller battery pack with LTO cells and leave those connected in the winter time. I'm wondering however, though, given that LTO cells have such a spectacularly large cycle life, if it wouldn't make sense to somehow interconnect the smaller LTO pack with the battleborn's somehow to put them in use in the summer too. I'm thinking that since in a normal scenario when it's sunny I barely dip into the total capacity of the LFP bank, cycling the LTO cells more often would give me better longevity on the LFP bank, and give me a little extra capacity anyway?
I realize that LTO cells are a different voltage, and I would have a smaller capacity pack but there must be some way to interconnect these two systems? Perhaps a programmable BMS + SSR to flip the bank over to LFP when the LTO are fully discharged? Or maybe buck/boost converter? It seems like in 6s / 12s configuration for the LTO would capture most of the discharge curve WRT the LFP cells . I don't even know if this is possible.... Any ideas?
