Outlook214
I have read and searched until my head hurts and I think I end up more confused, so I figured I'd just post a thread. I have an off grid cabin that we've used a generator for electricity the last 25 years. I am in the process of installing a 1170W complete solar system with a hybrid inverter/controller. I am installing a Square D 6 space indoor main lug load center. The camp up to this point has only had one circuit that feeds the entire place. I am going to put each room on a separate circuit, therefore installing the load center. There was no grounding rod at the camp so I just installed one. I understand I need to ground the solar panels, the load center and the hybrid inverter and circuits. My question is what is the right way? I read conflicting information. Since the load center is my main load center and not a sub panel, should my ground and neutral use the same bus bar and just ground everything through that bus bar connected to the newly installed grounding rod? Or, even though the load center does not have a separate grounding bus bar, do I need to add one? In which case I'd run all grounds to the added grounding bus bar that is attached to the grounding rod and all neutrals to the neutral bus bar. Thanks in advance!
