Offgridcabinman
New member here. I have an off grid property in E TN where I’ve build a well-insulated 300 sf cabin (plus upstairs) that just has the basic necessities. I have a small 5k BTW window unit, coffee maker, tv+dvd player, few other small devices. I’ve been running everything off a 3900/5000 Westinghouse Gen with no problems, even able to add another small window ac when company comes over.
New to me components and not installed yet:
1500w pure sine wave inverter. 8-AGM batteries @ 125ah each. Been used in a back-up bank for long time and simply aged out so they replaced them. Probably never been under a load of any significance. Not sure if that’s good or bad.
My question: Since I only go here every 2 to three weekends, could I use up most of the battery storage and let a small solar system recharge as I’m gone? I don’t want to invest much in the solar panels and charge controller so I was hoping less that $500 but I’m flexible. I can still run the generator but I don’t want to charge the batteries with it all at once because of that amount of power needed and would rather let a solar system recharge while I’m gone over time. I don’t have much sunlight there in the woods so that will also be a challenge. But I think my roof will be the clearest spot and still only get maybe three good hours of sun and the rest iffy.
I have an older aluminum tool box I thought about placing the batteries in and storing partially under the ground under the cabin so that in case of a battery issue I wouldn’t lose the cabin but also it will keep the batteries warmer in the winter and cooler in the summer.
Any thoughts would be great. I know this is the place to go for people who know a lot on this subject and are passionate about it, so good or bad give me your thoughts and knowledge. As my entry into solar just want to keep it simple and learn as I go and add to the system in the future.
