My off grid system needs to support a well, 2 zone mini split, lights and a refrigerator. My plan is to have two 14 panel solar arrays connected together in parallel and feed into the inverter. Each array will consist of 14-260watt (30.7 VDC, 8.50 Amp) panels in series (429 VDC @ 8.5 A each array, total 429VDC at 17 A). Optionally I could wire 14 sets of two parallels (wired in parallel) with each set connected in series through a combination box. What arrangement would work better for a full sun land based system? Which inverter woudl be better the Sol-Ark 12K inverter or EG4 18K inverter?
