Hey,
I’ve been reading up as much as I can on this forum and decided to go overkill with a Sol-Ark 15k for my cottage in Nova Scotia.
What I have to install;
-7kW of solar
- two strings of DC solar to Sol-ark
- 8x 230 amp 12V agm batteries
Electrical loads I currently have;
-115V /220V 1/2 HP shallow well pump (from lake). It is currently wired as 115V to the breaker panel. Stamped on the pump is 8.2 / 4.1 amps.
- lights that I need to switch over to LED
- dish washer
- clothes washer
Things I need to add;
- Starlink internet and wifi router
- security system with 4-5 cameras
- French door fridge/ freezer
- 115V, 9,000 BTU senville mini split.
In the future I’d like to add (and likely only run these when the batteries are full and I have excess power)
- 220V senville 24,000BTU mini split
- hot water heater (currently direct propane which I will still keep )
The last two future additions are a ways out, however I’m curious what rate I can charge my batteries safely and for good longevity, and if that setpoint on the all-ark will cause any issues with the surges I get when the well pump or mini split first cut in. Will I need soft starts?
I also need to decide if I should install the Sol-ark outside in a she near the electrical panel or in the utility room ( door to enter it is in our master bedroom, I’m worried about noise)
Any assistance is greatly appreciated!
Best regards,
Andreas
-7kW of solar
- dish washer
- clothes washer
Best regards,
Andreas
