Near Reno Off-Grid
- Jun 27, 2022
- 3
Greetings. I purchased an off grid second home 10 years ago approx an hour out of Reno. The system was well constructed. However, we are having to run the generator now 2X per day in the cold season when we have the radiant floor heat on. I purchased the "Mobil Solar Power" guidebook to check to see if the system is sized correctly. It appears to be. What I really need is an expert to consult with on battery options as I fear the Rolls deep cells are nearing the end of life. Also, I would like to not to have to travel 400 miles every 30-45 days to water the batteries. While I do most things myself (registered civil engineer and not afraid to get my hands dirty), I would like to find someone who would work with me to make sure that the appropriate equipment is purchased and ultimately installed.
Will - I see clearly that you are not in the consulting business (I think your guidebook is fantastic!), but maybe able to point me in the right direction? Much appreciated. Gary
