Ok, so this thread is an extension to my original 12V 3300W off-grid build here.
I started a new thread for focus.
What I've basically done is add additional RCD protection to the system by adding RCBO breakers to both AC outputs of the inverter.
Things you should know for context:
- Inverter has no N-G bond
- Inverter has no RCD protection
- Inverter 2 AC outputs / receptacles
- each AC output is running into separate RCBOs via the consumer/sub panel (see images & schema)
- N-G bond made in the consumer panel
My assumption
- If a get a ground fault on one of the AC outputs, then only the RCBO for that output should trip
Here's what is actually happening:
- If I simulate a ground fault on AC output 1 (I do this using the Low Impedance (LoZ) feature on my Digital Multimeter (DMM) by touching the DMM prongs on the RCBO), then both RCBOs trips
- Same behaviour goes for AC Output 2, i.e. if I simulate a ground fault then both RCBOs trip
Here's my questions:
- Can someone please explain what is going on here? I don't understand why a ground fault on one of the AC outputs is causing both RCBOs to trip. It's as if both AC outputs are on the same circuit?
- Are both RCBOs tripping because of the way the inverter is internally wired OR because I added a N-G bond? Can I do additional tests to confirm which?
- Am I causing any safety issues with my wiring?
Kinds Regards
GeeGee
Basic Schema
My assumption
Kinds Regards
GeeGee
Basic Schema
