Hi Everyone. I am currently in the process of installing my solar system for my Off Grid Cabin, soon to be home.
I will have a lot of questions as I proceed. The hardware I have is for a 48V system. I just set up my ground mount solar panel array, 6- 480Watt Qcells solar panels. Midnight MNPV6-Disco string Combiner Disconnect, Midnight Classic 150 charge controller, Samlex 4248 Split Phase Inverter, Samlex MN175SM-240 E-Panel by Midnite and a Sigineer 10KWH LiFePO4 Battery.
My cabin is a little over 100 feet away from my panels and I plan on using #4 stranded wire from my disconnect to the charge controller.
First question I have is hooking up the panels to my combiner box..I was going to run 3 strings of two panels? Also would like to know how I should ground this part properly?
