First - sorry for my elementary question and terminology ....
I am preparing to receive an EG4 12000XP. My plan is to send power to the XP by way of an breaker in my Main Electrical Panel (via the inverter GRID connection). The inverter would pass the power from the XP to the Main Breaker of the CRITICAL LOAD PANEL (via the inverter LOAD connection). All critical circuits will receive their electricity from the XP via this panel.
My question - If the XP fails but the grid is still up, I want to be able to provide power to the CRITIAL LOAD PANEL by working around the failed XP. It would seem some type of Manual Transfer Switch with the circuit from the Main Electrical Panel as the source and the XP and a DIRECT to CRITICAL LOAN PANEL (via a branch breaker) being the two "LOADS" from the Transfer Switch. I would then have to install a Generator Interlock kit on the CRITICAL LOAD PANEL to choose between the XP connection and the DIRECT LOAD connection.
After your head stops spinning maybe you can provide some feedback ?
Thanks
Thanks
