Hi all, I’m a new member of the forum but have been reading and trying to learn for a few years now.
We recently purchased a 2,000 sq ft log cabin cottage on an island in Canada. Currently it’s powered by a 4,800 watt generator and has mainly propane appliances.
-Propane stove/oven
-Propane combi fridge/ freezer
-Propane instant hot water (older unit, not enough output and maybe needs to be serviced)
- individual propane heaters in 3 bedrooms and 2 baths. One 40,000 btu propane fireplace in main room.
There’s a 220V pump with a small pressure tank around 8ft in elevation above the lake where we get our water. The cabin I would estimate is another 20-30ft in elevation from the pump and pressure tank.
I want to install solar with enough batteries to run lights, fridge, freezer and a load through a 120V dishwasher at night time. The majority of use for the cottage is from June to September, with occasional use in November, December, and April. Heating needs can remain propane and wood (if installed).
I’m trying to make a decision if I should go AC appliances, or if I should aim at doing as much DC as I can.
I am thinking a gravity tank for water use so I don’t require a lot of power at night. Maybe go DC for the pump and pump to an elevation of around 50-60ft. The cottage will be winterized when freezing conditions are present.
For hot water, I’d like to keep instant propane, but am considering adding solar thermal heat, or if it’s possible, a DC powered heat pump water heater or mini split that I could use the removed heat from the room to heat the water and get air conditioning in our bedroom.
The main question is, should I spend the extra for the efficiency or DC appliances, or should I keep things simple and run everything AC?
Thanks for any advise!
-Propane stove/oven
