Schneider should be good.
Victron too, though not UL listed.
SMA is good. Usually expensive, but still some liquidation deals thanks to DC Solar
Also Midnight.
Find many great new & used options and get the best deals for SMA SI6048-US-10 Sunny Island 6048 Inverter/Charger 120VAC 48VDC 6.0 kW NEW at the best online prices at eBay! Free shipping for many products!
www.ebay.com
"open box", actually says pull-out. So might lack battery temperature sensor, Ethernet patch cord, plugs for sensor and relay connections.
Sunny Island is particularly robust, good with lead-acid battery, generator, AC or DC coupling.
Using a battery shunt it can be informed of any DC coupled charging or loads.
If it has older firmware, should also work with Midnight Classic SCC and an adapter board to receive charge current data and control charge voltage (but not current). It can then adjust charge current from generator or AC coupled GT PV inverters to hit desired total charge current.
With AC coupling, SI only supplies starting surge and does charging during the day, or for loads greater than PV. At night it carries the loads. You can easily have 11.5kW of battery inverter and 24kW of GT PV inverter, supplies A/C and other loads while the sun shines. (Some model Schneider and others also now support AC coupling at least to some extent.)
I understand FLA is best maintained with a target charge current, so smart control of charging is best.
Schneider may do that with communication to SCC. Victron does that with Cerbo. Midnight does it with Wiz Bang Jr., SMA of course does that (unless DC coupled PV exceeds desired charge power.)
Also take a look at Midnight Rosie. That is from the guys who designed the orignal Trace, Outback, and others. It is high frequency, with 60 second surge rating. They also have newer SCC I think in the 10kW range.
