DevonBreeze
I'm trying to make use of a mini pc in an off grid cabin. And I'm hoping people can suggest things to help save power. The idea is that it acts like a server, mostly for security camera recordings so it's up and running 24/7. Currently it draws up to about 15watts (about 10watts in normal use, when a display isnt attached).
I'm using an n100 based gmktec g3 mini pc with 8gb ram and 500gb nvme ssd. And a generic touch screen ips lcd display. I wanted a gui, so it runs Win11 Pro, and does the job adequately. I know that a linux build could possibly be a bit more efficient but I have limited experience with Linux and prefer running Windows. I've been down the, Raspberry Pi as a server, route but it wasn't powerful enough for my needs without adding hats and all sorts of extras and that soon gets expensive. And I don't have the time to learn new OS's and how to set it all up. For the most part, it's an offline setup, running a media/file server when desired and occasionally going online for various light tasks, web-browsing, etc.
I run a relatively small solar setup (720w of panels), paired with a Bluetti ac200max unit. I cannot add or change this setup for anything larger so I'm forced to save power through software options or small (cheap) hardware tweaks.
Things I have done so far are:
-disabled any unused windows services
-set power option to 'high efficiency'
-enabled all the power saving stuff in the power options settings
-enabled cstate in bios
-set power option to 10w max in bios
-underclocked cpu slightly
-removed the wifi and bluetooth card
-changed the cpu thermal paste for higher quality (reducing the temp by 10c so the fan comes on less often)
-improved airflow into the case
-no usb devices plugged in
-runs directly off 12v from the Bluetti unit
The mini pc runs through an ethernet switch (3w max), which has several raspberry pis connected, again via ethernet. Each pi runs at 2w max with camera modules attached. It runs Contacam (I've yet to find better software for recording footage with motion detection in windows). And I only plug a small hdmi lcd touch screen panel in when necessary, so there is no monitor drawing any power in standby in the mean time. It's remotely accessable when needed too.
Overall the entire setup runs under 30w. I used to use a laptop as the server and that was 35w just on it's own.
I'd be very grateful for any tips, no matter how small or seemingly insignificant the power drop might be with your suggestions. It all runs fine in summer but in winter when solar panels generate considerably less power, powering things becomes more challenging, when other necessary devices are also draining power. Switching it off at certain times is not an option unfortunately, in my situation every watt is precious.
Is there anything anyone can think of to reduce power draw as I'd love to hear it? Seems to be a lack of info out there on low powered computing setups. Maybe there's a community out there I haven't heard of you could recommend? Thanks.
