ePowerBank
- Apr 13, 2021
- 133
Hello team DIY!
I need a backup power solution primarily for sump pump and secondly for home backup power.
I plan for sump pump backup to be automatic, and home backup to be manual, hence split phase.
My original favorite was Magnasine MS4448-PAE, but just too expensive I think for this case, and seeking something more like a UPS, Plug N Play.
I actually looked at a Sump (modified) inverter by Sentry that starts at almost $1000 (without batteries), so I think below options are major upgrade that allow for the backup power to boot.
With a sump that pumps twice a min worst case and wanting a home backup option for evening power, I'm thinking 48v 100AH EG4 by Signature Solar for the battery ($1500).
My latest short list has is 3 options, and, I would love to hear what the survey of those experienced have to say…
1. Growatt SPF6000T (connects to EG4 100AH I believe, best warranty, but no UL1741)
2. Sungold Power 6000W 48V split phase (UL1741, but no BMS connection)
3. Sigineer M6048D (seems simple like Sungold but a little better, but no real advantages over 1st or 2nd options)
Would it be an issue if I didn't have UL1741 with the Growatt?
On the other hand, would it be an issue if I didn't have EG4 connected to Sungold inverter for BMS?
Funny, I just learned that the Sigineer has what looks identical model (M6048DUL) for $2000 ($+200) which includes UL1741 - hmm, Sungold looks golden?!
Would welcome any votes, or suggestions for what's the most Plug N Play!
RESPECTFULLY TORN !
Growatt 6kW Split Phase Off-Grid Inverter | SPF 6000T DVM-MPV
Signature Solar provides solar panels, off-grid solar systems, grid-tie, and hybrid systems. Quality solar inverters, bifacial solar panels, complete solar kits, solar batteries. Featuring brands such as EG4 Electronics with their solar battery, LifePower4 and EG4 LLifePower4 and EG4 LL
signaturesolar.com
6000W DC 48V Split Phase Pure Sine Wave Inverter With Charger UL1741 Standard
Sungoldpower 6000W DC 48V Split Phase Pure Sine Wave Inverter With Charger. Hightlight: This 6000 watt Pure Sine Wave Inverter is a combination of an 240v inverter dc to ac, battery charger and AC auto-transfer switch. Low frequency, low Idle Current, remote control. Adjustable Charging Current...
sungoldpower.com
6000W Solar Inverter 48V to 120/240V Split Phase Off Grid Hybrid 80A MPPT Charger ETL Listed
6000W Solar Inverter Converts 48V to 120V 240V ac split phase pure sine wave. With UPS transfer switch & 80A MPPT charger ETL Listed.
www.sigineer.com
RESPECTFULLY TORN !
