Thank you. Timer switch saved, I like that one better. Its definitely a much more conscious device.
Ok, If I purchase MPP or Growatt, I'll use watts 24/7, not ebay.
On the AIO side, is there a competing product in growatt or another manufacturer that is a better package in your opinion? Less idle power draw? Even if I run two lower cost hooked up together.
Playing devil's advocate, what would be the 48v inverter you would recommend? I know Michael recommended the Schneider at 3k+. Also the SCC you would recommend as well? It seems you are an advocate for Victron. I'd like to see what this method would cost and compare to the AIO. I realize the AIO is more simple to set up and cost effective, but if I'm limited in expandability or some other blindspot in the future I'd like to know.
The Audit calc is currently telling me 433Ah of batteries for 2 days of storage. If I order the 280AH eve cells from Amy as you did. I would need 16 to build a 48v 280Ah battery correct? What is the rough cost per cell? In a perfect world I would double that to create 560Ah which would give me 2.5 days of storage. Would I need 2 - 48V BMS for the 2 separate packs of 16 or can it be accomplished with one?
My apologies if these are simple questions. Solar and power is a brave new world for me. Thanks again for the help.
